Rim Light Rig
in New Users
Hello,
Has anyone used a Rim Light Rig set of lights: http://www.daz3d.com/rim-light-rig
Whatever I do I end up with the complete black figure or completely lit up scene?
Thanks in advance
That light set is for 3Delight render engine. Are you using 3DL, or Iray?
Yes, I have it and love it. It is for 3Delight, not Iray. (Marshian's new Body of Light set does have rim lights in it, but they're different than these.)
The Rim Light Rig is a great set with a lot of flexibility. I made this promo for my superhero series with it. The hair shaders are wonderful and easy to use. For postwork, I used Ron's Light Fusion brushes to add the energy effects.
Probably need to rotate the rig. If the lights are a group, select the group and use Y rotate in the parameters tabe to position the lights until you are getting the desired result in your preview window.
momirborocki- did you figure this out? I can help answer questions. Llynara- thanks for posting such a delicious render!
Did anyone figure this out? I'm having the same problem but am dying to try this. It looks awesome! Is there a tutorial somewhere or at least something that shows settings? I see some are saying it is for 3DL and not Iray but I don't seem to have the option to change. Sorry for my ignorance and thanks in advance
The set that is linked by momirborocki is for 3Delight. Make sure you are using the one for Iray if that is what you are rendering with.
