Persona Non GrataPersona Non Grata Posts: 1,365
edited March 2021 in Carrara Discussion
Post edited by Persona Non Grata on
  • HeadwaxHeadwax Posts: 10,019
    yep I had the same problem - to fix do this
    I started with a plane with around 576 polys and a cube mesh around  1014
    In VWD I reset all parameters via Utlity Button
    I then upped the subdivision in both the cube and the plane - I also increased the friction in both
    doing this fixed the problem
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Thank you for asking this, Selina.... me, too!!  yes Silene
    edited March 2021
    edited March 2018
    Selina said:
    Thanks Andrew, I'll try your suggestions and see where that get me :)
    pleasure :) it's great when it works .... I did most of the medieval clothes for the Hugo Ball show with it
    Post edited by Headwax on
    edited March 2018
    hi in this is a video - watch the polygon count in the mesh room as it jumps up - I went overboard (just hold plus key down till you get lots of polys) so you probably dont need so many
    in vwd I ticked subdivide changed the softness and stretch (?)  and friction
    the txt file attached is the car file - just rename the suffix to car
    txt
    txt
    vwdcubeandplane.txt
    2M
    edited March 2021
    edited March 2021
    edited March 2021
    edited March 2021
    edited April 2018
    Great news.  Looking forward to it.  Happy to be taught new tricks.
    Selina said:
    Oh and by the way...
    If you do not already know, Gérald is working on a new version that will make better use of your graphic card's onboard GPU and should eliminate the "x.obj" not found error due to a timeout issue.
    Sorry if I sound like I'm trying to teach old dogs new tricks for those of you already in the loop.
    ​Selina
    Post edited by Diomede on
    edited April 2018
    Selina said:
    I have spent what little time I could today to try and iron out my difficulties (ie lack of understanding)... and here are my three attempts:
    1. My first attempt has holes between the models faces. I think it is to do with the 'stretch' spring setting
    2. My second still has a tendance to slide off the model - but not so much. I think this has to do with the number of vertices the collision model has in relation to the cloth model
    3. My final of the day is starting to look a bit more like it.
    PS the blue cloth is a wink to that fabulous blue found on older masterpieces ;)
    hey glad it worked out - great news about the gpu,
    one of the problems with the program is that there is no list of presets as there are in the poser cloth room -lack of presets make it harder to grasp
    the manual however is a good read :)
    edited March 2021
