Persona Non GrataPersona Non Grata Posts: 1,365
edited March 2021 in Hexagon Discussion
Post edited by Persona Non Grata on
  • Sfariah DSfariah D Posts: 26,504
    Oh, I never thought of it.  At first I thought you were talking about a realistic star (like the sun which is a star by the way).   Now I see you are talking about a toonish star. Put a face on it and rig it and it becomes a toon starfish.
  • I'd do them about the same way as you did. Doing something similar with 6-fingered creatures.
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
  • nonesuch00nonesuch00 Posts: 18,269
    I would turn off smoothing but build them the same way it looks like you have done.
  • mach25mach25 Posts: 256
    edited August 2018
    1:first approach I trained alot when modelling was extrude/sweep ,and I experimented with octagon and other shapes so I made a fish,you know the approach like modelling with clay
    2:build up shape with different primitives I see you have tried that one too
    3:if you have engineer background/CAD, you maybe is more used to use 2d curves/lines and extract a 3rd dimension ,I made a heart that way,some objects are perfect for that technique
    I think you did a great job Selina
    Post edited by mach25 on
  • The last star I made was an origami style one, 4 points with a flat cube in the center.
  • Retro LadRetro Lad Posts: 471
    Selina,
    Have you been watching, "Warning from Space."? It is one of the goofiest of the 1960s Japanese SF films. I attached some screen shots of the alien star creatures from the film.
    How about being lazy and using Corel Draw for the shapes of your "stars" and then extruding them in Hexagon, or by using the new "cutout" plugin for Carrara and then puffing up the "star" shape with the balloon option.
    640 x 480 - 27K
    640 x 480 - 28K
    edited March 2021
    Selina,
    I do not have Corel Draw unfortunately any more.
  • AscaniaAscania Posts: 1,855
    Selina,
    Then use Inkscape instead.
  • SweetleafSweetleaf Posts: 32
    edited August 2018
    I hope you don't mind, but I used this as a quick exercise. These were my two.
    One was created from a cylinder and the other from a sphere.
    zip
    zip
    Starries.zip
    12K
    Post edited by Sweetleaf on
    edited March 2021
  • Well I was quite surprised that it actually didn't crash during the making of either of thsoe two stars. I will attempt to make a step-by-step for both of them in the next few days for you.
    This video may help. It is for Blender, but the basic modeling methods can be replicated in Hexagon. It is on how to make a "starfish". I would jump into this challenge but I am busy with a Bryce animation and want to get it done before I start loosing enthusiasm for it from frustration and annoying render times.
    https://www.youtube.com/watch?v=Trzmf3GleAs
    well almost wrote a poem about stars(it doesnt rhyme) and want to make something that match it
    edited August 2018
    just for fun I tried with lattice,but to make something with precision you need to have control of make it with help of hires greyscale map made in 2d program and import it
    so I guess I have to make star with hexagon and import to my animation,just tested with make a animation that shows many aspects of star,unfortunatly exporting it to gif doesnt work well
    thanks Selina for making me use incremental save all the way,not a toon star,but different star
    1:started with cones and tested different numbers of sections until I choosed 32 different sections around+minimum sections
    so it looked like 32 pizza slices
    2:cut out 16 of them,every other
    3:rearranged them so their pointy ends became outwards until I got a 2d star with 16 points
    4:mark all 16
    5:open up surface modelling and choose thickness tool,choosed 0.025,choosed some blue-ish material
    6:made few copies of the 2d star and tested to have them rotated at different angles,choosed zero,30,60,90,120,150degrees 6x2dstars
    7:added a sphere in the middle,that is transparent,added some transparency,tried some smoothing
    Mach
    743 x 556 - 63K
    743 x 556 - 114K
    743 x 556 - 40K
    743 x 556 - 57K
    753 x 567 - 114K
    edited March 2021
    Selina said:
    Beautiful stars mach25 - like Xmas decorations yes
    Thanks Selina, maybe need a different animation than a 24hours animation presented in seconds I made,too many colors to work in 256color gif
  • cdordonicdordoni Posts: 583
    Thanks to 64-bit beta... Copy on Support can make some really cool things with millions of polys
    1880 x 873 - 217K
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited August 2018
    That looks great Cdordoni - The 64 bit version great isn't it :)
    Edit - I need a new keyboard, some of the white lettering has worn away :(
    Post edited by Wee Dangerous John on
    That looks great Cdordoni - The 64 nit version great isn't it :)
    It is great ... hopefully someday it will get retopology tools too.
    question is,when you are not following learning some new feature/following a tutorial,maybe the idea/approach comes from our background,consciously or subconsiously?
    I have two ideas,one I want to try Sun render,still in WIP stage
    second I got stuck on howto make use of carraras randomized duplicate function on a terrain,sorry forgot howto
    edited August 2018
    I want to do a closeup render on Sun,so it requires some sunflares
    here is WIP,the small one is supposed to be replicated over surface,the thin red one is also to be replicated
    ooops the "ball" and some other things are supposed to be below ground
    big one,make several different big ones and some sunsurface testrender
    maybe better make transmapped paintings for textures would be better?
    the star in front is suppose to be for white highlight
    1200 x 1200 - 1M
    1004 x 566 - 305K
    640 x 480 - 111K
    640 x 480 - 95K
