Surfaces Copy and Paste
How do you copy a surface to use on another object
  • Select teh object and the surface(s), then use Edit>Copy>Copy Surface. Then select the target object(s) and surface(s), Edit>Paste>Paste Surface(s) (from memory - it's the Copy and Paste sub-menus you want, anyway).
  • barbultbarbult Posts: 24,863
    Both surfaces need to be using the same shader for it to work.
  • True, yes - you can aply the base shader before pasting the settings.
