Can you remove/ delete a Lie tattoo from an image?
atacit_23cd333971atacit_23cd333971 Posts: 101
edited December 2018 in New Users
[Can you remove/ delete a Lie tattoo from an image?] They seem alot like a real tattoo. Once they are applied they are forever? I have tried removing them in the lie editor with no luck.
  • there would be another file somewhere created it's using
    it usually is in Daz folder DAZ temp in documents
    you need to swap that with the original texture file in your library runtime textures the PA who made it's folder most likely, look at another body part to find the path
  • RedzRedz Posts: 1,459
    You could simply reapply the base character skin, though this may also affect makeup options etc.
  • Thanks, I ended up just reapplying the skin for times sake. I just wanted to make sure there wasn't a "click" I was missing.
  • Seven193Seven193 Posts: 1,111
    In the Layered Image Editor, you need to delete the layer. Unchecking its checkbox won't delete it.
    At the bottom right corner of layer list, there should be two buttons, + and -.
    Select the tattoo layer, then click the delete button (-) to delete it.
    Click Accept, and the tattoo should be gone.
    Post edited by Seven193 on
