Headshop/ Loading existing .obj
Hi,
Headshop 11, V8 figure.
Apologies for asking a noob question, but I can't seem to load an existing file into Headshop.
At the first menu, I check 'Load existing Headshop OBJ:' and specify the file.
Now I get an error telling me that the selected file was not created with Headshop (it was). On hitting 'OK' I'm then locked into 'Specify a different texture map' on the same menu.
How do I continue?
Thenks
Chrissy
  • info_b3470fa520info_b3470fa520 Posts: 897
    edited January 2019
    An easier way to load existing figures created with HeadShop in Studio is to save the figure as a scene and than load scene.
    Same applies if you want to load several HeadShop figures on stage at once; use "Merge" in DAZ Studio under "File".
    You can also send an email to tech support at [email protected]
    Post edited by info_b3470fa520 on
  • Thanks for the reply.
    Does this mean then, that I can't save a face and edit it at a later time?
    edited January 2019
    You can save the OBJ under "Save" but you won't be able to edit it in HS11.
  • OK. Thanks for that.
