need help!
in New Users
I tried to use the help center. But a lot of the information that they want does not apply. Then when I look at one of the options and i realize it doesn't apply. Then I hit the back key. And everything I filled out on the ticket. Disappears.
My problem:
I have been a member of this site for a long time. This is when poser was version 5. Somewhere back in the early 2000s. Through the years I would be on and off again. I believe what I did was start new accounts. I remember buying products that are not in my account now. Mimic lite and mimic Pro. Amongst other things. How can I get all these things in one account?
People on the forums are only store users, you really need to file a support ticket for a question like that.
You would need to find the emails for the old accounts.
When you go to ZenDesk from Daz you are often not logged in - click the Sign In button at top-right and you should be, and then won't need tore -enter the basic information.
Zendesk is where you create support tickets, you go there from Help menu in the store then Contact us > Submit a help ticket
According to the screenshot you didn't fill some required fields in your ticket
You need to compleet those fields - the Tech one can be NA, I think, or Not an Issue, and you can typ NA into order number. For the other two, picjk anything since it isn't relevant anyway.
If you look at the URL when you're in Help Center you'll see it says "zendesk".
