Rendering only part of a set?
DekeDeke Posts: 1,635
I recall reading that there is some way put some sort of plane into a set and then be able to render only parts on one side or ther other of that wall.  Is that possible?
  • Sounds like you are looking for an Iray Section Plane, which makes everything on one side of it invisible in the Iray render.  Can be a bit tricky to position
  • DekeDeke Posts: 1,635
    That did the trick. Thanks for the reminder. So many features I forget what does what.  Makes rendering in layers easier.
