Duplicate files?
I got an error message loading an older scene. It was something like "duplicate files have been found. Verify that the content is properly installed. See the log for more details" (not the exact wording). I looked into the log file, and I saw this :
2019-02-23 04:05:37.816 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-23 04:05:37.843 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-02-23 04:05:37.845 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
And this (there are much more similar lines, didn't want to post them all) :
: 2019-02-23 04:05:29.868 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis3Male:/data/DAZ%203D/Genesis%203/Male/Morphs/DAZ%203D/Expressions/eCTRLTriumph.dsf#eCTRLTriumph?value in file : /data/DAZ%203D/Genesis%203/Male/Morphs/DAZ%203D/Michael%207/eJCMMichael7TriumpHDLv2.dsf
2019-02-23 04:05:29.874 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis3Male:/data/DAZ%203D/Genesis%203/Male/Morphs/DAZ%203D/Expressions/eCTRLSerious.dsf#eCTRLSerious?value in file : /data/DAZ%203D/Genesis%203/Male/Morphs/DAZ%203D/Michael%207/eJCMMichael7SeriousHDLv2.dsf
2019-02-23 04:05:29.875 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis3Male:/data/DAZ%203D/Genesis%203/Male/Morphs/DAZ%203D/Expressions/eCTRLScream.dsf#eCTRLScream?value in file : /data/DAZ%203D/Genesis%203/Male/Morphs/DAZ%203D/Michael%207/eJCMMichael7ScreamHDLv2.dsf
What am I supposed to do, if anything? The scene seems to have loaded normally.
  • The Cannot Find Target errors are no problem - they just mean that you have Michael 7 but not the Genesis 3 Male Expressions (I think) so the correction morph to make them work nicel with Michael 7 can't be hooked up, but you don't need it so no loss.
    The vertex count errors are a problem - they indicate that the morph affected is not set up correctly and will not work.
    There aren't Duplicate Files errors  -there are Duplicate Formula and Duplicate ID errors. Without knowing which you had it is hard to ofer any suggestions.
  • odasteinodastein Posts: 606
    Which what I had? Formulas? ID? Morph?
    Should I be worried? As I said, the image loaded normally. Do I have simply morphs that won't work? Should I look for that?
  • My 3D SpinMy 3D Spin Posts: 608
    edited February 2019
    I get these errors as well sometimes- Just ignore it. The scene will load fine anyway!
    edited to fix quote
  • The errors would indicate a problem with a piece of content, and if it's a conflict between two pieces of content it will mean that one definitely isn't work correctly. For example, I ran into a morph conflict (two morphs, in different products, with the same name) and as a rsult one of the moprhs simply wasn't loading - renaming fixed this.
  • I have the same problem, If anyone finds solution for this please tell me.sad
    Which same problem? With which product(s)?
  • xyer0xyer0 Posts: 6,058
    I began getting a "Duplicate Formulas Found" message after installing Ronnie for Genesis 3 Male and Takeshi for Kenji 7 last night. Any Genesis 3 Male I load now throws this error, and loading ceases until OK is clicked.
