Persona Non Grata
Post edited by Persona Non Grata on
On my machine, the test file rendered in just under two minutes. You can find my specs and render time for the champaigne bottle scene that comes with Carrara for comparison purposes. Check this thread.
https://www.daz3d.com/forums/discussion/365576/getting-new-machine-yay-installation-frustration-to-follow/p1
Oh, sorry, I can't test that right now. My desktop and laptop are not together. Wednesday is the earliest I can try.
This thread might help. https://www.daz3d.com/forums/discussion/112451/carrara-not-using-all-of-my-render-nodes-solved/p1
Also make sure everything you have installed on the main computer is also installed on the render node, this includes all plugins, all content and all modified content like shaders.
well my serial number for both Carrara 8.5 and rendernode is coming up invalid on my old win7 computer and DIM won't update and install
the beta still works
I might end up having to put Win10 on that PC after all if nothing will work
well I did get it to take but it's blank like rendernode
and if I use my other version, an earlier build in another folder I get this
going from my other computer 5040 port error
OK changed second port to 4030 on both computers
Houston we have lift off!!!
time 2.29
so yes faster 12 tiles
not Octane as that needs a Nvidia card and only have one on my Win10 PC
yes use it mostly
this will be handy for metaball particles etc though
i remember seeing flickering using node avi renders. havent tried it with my newer machines or png sequences
I am beginning to think animations best done in separate sequences myself
presumably my 8 "N " tiles are on the next frame already
my other PC is using it's CPU but if it has to wait for frame 3 this is slower
it also cannot find Alpha Tango's leaves
the second PC
yeah frame 3 no tiles from master PC this is pointless
it does one frame each PC
and I tried a Howie farkes scene and it made me look for every map before the second PC would join in
i'd rather use the 2nd pc to start prepping content for the next scene
Good Day here are some other links from the past that may help.
If an image/frame finishes but you have a few N left on the screen then it is most likely a network connection issue.
I ensure that all of my networked machines are on a physically wired network and not connected by WiFI.
also that speeds up communications between nodes as most wired connections now default to 1 Gb/s and WiFi is not at that speed yet.
https://www.daz3d.com/forums/discussion/120456/tutorial-how-to-set-rendernode-to-start-when-windows-10-machine-starts/p1
https://www.daz3d.com/forums/discussion/comment/1683406/#Comment_1683406
https://www.daz3d.com/forums/discussion/comment/1572736/#Comment_1572736
https://www.daz3d.com/forums/discussion/comment/760847/#Comment_760847
https://www.daz3d.com/forums/discussion/comment/589269/#Comment_589269
Hope this helps.
Having looked at the other links I just want ot make sure that on your primary or Master Carrara machine you do not have RenderNode Running as that will cause all sorts of problems.
It should only be on the nodes not the master.
Currently, render node is not for me. I want to be able to use Carrara separately on my laptop and my desktop, and I have very little extra stuff installed on my laptop. Having stuff match would be a problem.
