syncing Bryce 7.1 Pro SMPTE
sa
Is there a tutorial that examines , within the animation processes of Bryce 7.1 Pro , processes and abilities of syncing Bryce 7.1 Pro SMPTE with the SMPTE of Cakewalk SONAR X1 LE 64 bit ?
David Brinnen mentioned in one of his tutorials that he had done animation for Musicians
Is there a bridge ?
Would be cool noting this ability to sync with Cakewalk , Roland , U.S.. and Edirol :)
or
Can I import .WAV into Bryce 7.1 Pro ?
there is no way to import .wav .
maybe David was talking about older version .
you can do animation - but not DS or Poser models .
Thank You BIGH .
I realize that , in the past , the usual procedure has been any audio content be created to fit the animation .
That then , must have been the reasoning to include SMPTE .
My process , seamlessly create animation to existing audio content .
As Bryce 7.1 Pro offers SMPTE as a preference , and if SMPTE can generate metadata in both directions , much like MIDI scripting
language , I can't help but wonder if a bridge already exists .
Cakewalk Sonar does allow the import of animation , it does support SMPTE and MIDI .
The setup does allow other Applications control as Master or Slave .
I don't have to import .wav , I would be excited to have separate Applications open at the same time , talking to each other .
It is a most interesting minimal information problem .
