Can't load Victoria 6
wassean_1fcf286464wassean_1fcf286464 Posts: 21
I recently purchased Victoria 6, which the website says is compatible with Poser. I have poser 10 and have imported the victoria 6 files and refreshed my downloads, yet I can't find her in my library. Help.
    Do you have the DSON Importer for Poser installed, and did you install both "Victoria 6" and "Victoria 6 PoserCF"?
  • wassean_1fcf286464wassean_1fcf286464 Posts: 21
    I believe I imported the Victoria 6 PoserCF files. What is the DSON Importer for Poser?
    http://www.daz3d.com/dson-importer-for-poser
    It's a plugin for Poser to allow it to use DAZ Studio .duf files.
    Alright. Tried to download DSON 64 for Poser 10 and this is the error message I got. Any suggestions?
    Install Manager cannot find a required path. The package for "DSON Importer for Poser (Win 64-bit)" requires that the installed path for "Poser Pro 2014, Pro 2012 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
    Poser 10 is only 32-bit. In DIM, click the Settings (gear) icon in the upper right corner. CLick on the Applications tab, and click the plus sign in the lower left, and add the path to Poser 10 (e.g. Program Files (x86)\Smith Micro\Poser 10). Then install the 32-bit DSON Importer.
    Alright 32 bit is downloaded. Now how do I use it to get victoria uploaded into Poser? Still struggling.
    Look in the Figures library in "DAZ People"
    Unfortunately, there is no DAZ people in my Poser figures library. UGH!
    Where did you install "Victoria 6" and "Victoria 6 PoserCF"?
    I used the content tab "install zip files." I uploaded both Victoria 6 and 4.2, as well as, the support file. Nothing. I am obviously doing something wrong.
  • scorpioscorpio Posts: 8,481
    Victoria 6 is a morph for Genesis 2 Female not Victoria 4.2.
  • Richard HaseltineRichard Haseltine Posts: 102,770
    Install the DSON Importer to your Poser application folder (which you've done).
    Install Genesis 2 Female Starter Essentials (should have come with the DSON Importer) and Victoria 6, plus their PoserCF files, to your Poser content library - the folder that holds the Runtime folder. If you are unzipping manaully it's the files and folders inside the Content folder in the zip that you want to merge into your library, you don't want to have the folder called Content itself.
    Victory! It worked! Thanks everyone for your help. I really appreciate it!
