Grey line arround genesis 2 character on Poser Pro 2014
Baba02Baba02 Posts: 0
edited June 2014 in New Users
Hello, :)
Sorry to bother you, but it's been a while that I search myself an answer to fix my problem, and now, I need some help.
First, I show you a picture from the software Poser Pro 2014 :
http://image.noelshack.com/fichiers/2014/26/1403720124-problem-subdivision.png
My problem is as you can see, there are a lot of grey line around my female or male character genesis 2. I can disable it when I put the subdivision level at -1, but I want the best resolution and for that I need to put it at 2! I think the problem disappear if I make a render, but I want to stay in preview mode for an animation. I hope you can help me! Thank you for your help and I hope you've understand my problem with my english :red:
Post edited by Baba02 on
  • Richard HaseltineRichard Haseltine Posts: 102,770
    I don't think that the line can be hidden in preview mode with SubD on - it's a consequence of the way the importer generates the SubD mesh from the base mesh.
  • Baba02Baba02 Posts: 0
    Thank you for your answer.
    I'm a very disapoint if it's not possible so :shut:
    Maybe a solution can be found, for exemple, when I selectionne a body part like the head, and disable the box "visible", only the head is without the grey line. Of course I won't disable one per one any body part, because this will take me a lot of time! Moreover, if I do that I can't move the body part I've disable. I've tried to select all the body, and disable the box "visible" but that doesn't work.
    Maybe someone else found a solution?
    (oh and sorry for my english if I made some mistake)
