Textures on Props without Texture
lydia.jasminlydia.jasmin Posts: 2
I tried to change the texture of some objects.
I recognized that it is very easy to change the texture of objects which already have an texture in the texture folder,
but if I want to change the texture of one which doesn´t have a texture or just a color it doesn´t work.
what can I do?
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,591
    those items are probably not UV mapped
    in 3D space you have x,y,z cartesian co-ordinates
    u,v are the 2D equivalants if you flattened the model out unfolding it on a flat surface.
    a UV unwrap program can do this, there are a few free ones
    to see if it is UV mapped look at it in UV view in Daz studio
    if it is you will see a grid map
    if not a dot or line
    you can obj export it to load in a UVunwrap program, unwrap it and re-export it the new model will take textures
    there should be some simple unwrap options such as planar, box, spherical and cylindrical to pick from
    pick what ever is nearest to the shape of your chosen model and the axis it is on.
  • lydia.jasminlydia.jasmin Posts: 2
    Thanks, do you know where I can get such a program from?
    UV mapper has a free version http://www.uvmapper.com/downloads.html
  • frank0314frank0314 Posts: 14,313
    IMO The two best for uvmapping are UVLayout and Ultimate Unwrap 3D
    I use another paid program but this one is free http://www.uvmapper.com/
    edited June 2014
    ooh mods too quick
    yes I use UU3D ultimate unwrap 3D myself
    lthunwrap is a lite version of it free on sharecg
  • srieschsriesch Posts: 4,241
    A second option is to select the surface and apply a shader to it, if you wish to use one of those rather than wrap an image file around it.
