which sets render faster than others?
AristocAristoc Posts: 254
i noticed some sets render really fast. Then when I use another artists set it renders really slow. The only thing I changed was the set. Same lights and characters.
How can I tell which sets will render faster before I buy?
Thanks
  • TotteTotte Posts: 14,098
    Render time is a very complex relationship between many different things, to mention a few:
    - Light settings
    - Displacement maps
    - Transmaps
  • frank0314frank0314 Posts: 14,313
    edited July 2014
    Poly count of an object is also one. There is no way to tell how something is gonna render before you buy it.
    Post edited by frank0314 on
  • SickleYieldSickleYield Posts: 7,644
    Thanks
    Size of the set matters. If it's a set that is one giant piece, and you can only render it as one giant piece, it's going to go slower. If it has a lot of smaller pieces, and you delete the ones that aren't in front of the camera, it will usually go faster. Poly count matters also, and that's not something that can be told from a product description; it can only sometimes be told from the renders.
  • pwiecekpwiecek Posts: 1,582
    edited July 2014
    - Light settings
    - Displacement maps
    - Transmaps
    Overlapping Transmaps are particularly troublesome.
    Post edited by pwiecek on
  • AristocAristoc Posts: 254
    one way to tell, as i seem to be able to do so far, is that ' older ' made products render faster then the 'new' ones. here is an example. 'Loft4lease' vs 'hot tub pergola'.
    That could also be because it is a different PA. Pred's models do tend to be reasonably mid to low poly compared to some other vendors, and his textures are often smaller in pixel size, which also helps.
