A noob needs help about G2F breast, please *SOLVED*
Hello everyone
I've just installed Breast & Glute Control Morph from Zev0. Now, I'm able to create breast movement for example the hanging breast when bending down. Unfortunately, this product is for Genesis only. I actually don't really like Genesis & prefer Genesis 2 Female or Victoria 6 (they both have nipples & they have better skin). I'd like to apply the same position with G2F/V6 but not able to create the hanging breast. Is there any morph which have the same purpose like Breast Movement Control & designated for G2F/V6? If there's no such morph, what should I do to make the hanging breast? Could please give me some tips & advice if possible.
Thank you very much
Regards,
King_of_kerb
Post edited by tititlemot on
If only I could remember what morph pac the "Natural" slider came from (For G2F). As for movement, the Pectoral on the scene tab seams to do allot for mimicking natural sway from walking, etc.
(edit)
here is at least a screen cap of the slider, and the nodes/bones in the scene tab that do the chest movement (using the parameters tab) let me look at the G2F packs I got back in march.
"O" click the gear, open "parameter settings" and turn off "Use Limits" (also for the left and right sub-sliders as well) if you need more then the slider will allow.
"Natural" slider came from Shape Shift (also from Zev0) if I'm not mistaken, but it can't create the hanging breast for bending down body pose. I'm sorry I forgot to tell you, I didn't create a movement, I created a still 3D images.
Thnx for your reply, zarcondeegrissom
Your correct, for hanging, it just makes them "Fuller" with the up-down slider that way. Hmmm.
Z-Scale it up...!!!
Ah, I get it now. Ok, I'll try your advice & let you know as soon as possible.
Thank you very much, zarcondeegrissom!
your welcome, and thanks for remembering what morph pack that was from. I purchased a bunch of packs, and installed them all at once.
And as a side note, I'm skirting the fine-line with that one screen-cap. be careful what screen-caps and renders you do post, TOS.
Dear zarcondeegrissom, I already open Pose & Animate bar & I select the left pectoral but there are no X, Y, Z-scale bar on it.. What am I suppose to do to make it appear?
Thnx mate
Image removed
I am so sorry about that, there "Hidden" properties. It's simple to bring them up in any the tab.
I think this dose it for ALL hidden properties there. Including "Hidden Morph sliders" for clothing.
I found it, but it seems that I need to set the parameter first. How to do it?
Thnx
slightly confused by your question. Are the sliders there with that check-mark-box checked (from my former post)?
If it is gray, just try moving the slider, or click the "100%" text, and type in a number.
Or is it something else?
Ooo I see, they are in "Scale" bar.. I thought they are in "Translation" bar. My mistake. Ok I got it. Thanx mate
I go one up to "Transforms" to see them all, unless it is too busy. And with Daz Studio, Just because it is gray, dose NOT imply it will not do something. Many save windows tripped me up with that.
Thank you very much for your help.
Oh, and one more thing. It's out of topic actually, but I hope it's fine.
I have installed Michael 6 Pro Bundle & I found his genital & installed it as well. When I put his genital onto Michael 6, the genital appeared in different color, it was all grey. Some part of his lower belly also appeared in grey. What was wrong with that and how can I fix it? (I'd like to put a pic but I'm afraid it's forbidden because it contains genital, but I hope you understand about my problem)
Thnx again
I found it! Sorry to bother you.
Anyway thank you for your answers. I really appreciate it
Glad to see your figuring things out, and having fun from the sounds of it.
There are some free "Interactive lessons" included in Daz Studio. If you have not done them yet, They may help allot. I didn't do them for a month or so after starting out, and wish I had done them first day.
There are other free lessons at the store, tho some of them require stuff to be purchased for them to work. Don't just buy stuff yet, do what you can for free lessons. Then when you figure out your own style of stuff you want to work with, then look around, and ask questions.
Have fun, and I look forward to seeing your renders around.
Just keep that "G-rated" thing in mind here at the Daz forum.
I will! Thank you very much!
