How do I install Victoria 4.2 into Poser 9
flyinfurflyinfur Posts: 0
edited August 2014 in New Users
How do I install Victoria 4.2 into Poser 9. The title says it all. I've checked the forums on here for about an hour and found nothing. Hoping someone can help.
Thanks!
Edited to add question to body of post
    Victoria 4 is in Poser format, and it will install into a Runtime folder.
    Open the ZIP file, and if you are using a PC, merge the Runtime folder inside the ZIP file with the Runtime folder that Poser 9 uses.
  • flyinfurflyinfur Posts: 0
    Thanks. That's actually the first thing I tried. It works now, not sure what I messed up first time through. Thanks again
  • info_7ab70978f3info_7ab70978f3 Posts: 78
    Is there a "Content" folder in your Poser 9 folder?
  • Richard HaseltineRichard Haseltine Posts: 102,770
    Please don't do that - the title may not be immediately apparent to someone reading the thread, and it should not be any great effort to add the text to the body of the post.
