problem with node instances
calaopiecalaopie Posts: 215
edited August 2014 in New Users
Something strange has happened to the New node instances .For some time I had no problem with it. Load object, used this option and record how many objects I need it and this work fine.
Now when I create a group and trying to move an object I can only move the primary object, that which I used to copy.
It is very frustrating, because so far has well
Open the Scene tab; click on the arrow to open the instances; click on the instance you want to move and it should move independent of the rest.
I know but i have to many objects ,to much time it will take me. Previously, I could move and select each object in the group. Now I can do just as you wrote.
Post edited by calaopie on
  • FishtalesFishtales Posts: 6,162
  • Richard HaseltineRichard Haseltine Posts: 102,778
    I have no trouble clicking on the instances - what tool are you using? What settings do you have for it in the Tool Settings pane?
  • calaopiecalaopie Posts: 215
    LOL ,I had set to Surfece Selection , changed on universal and work correct XD .Why I lost in such simple things.
