mcjBigView: DS 1-4 script converts google-image-search results to BIG image
mCasualmCasual Posts: 4,607
edited November 2014 in Freebies
https://sites.google.com/site/mcasualsdazscripts4/mcjBigView
you save the google search results page to disk, just the html page, not even the thumbnails
run this script
and you get an html page which lets you view all the huge versions of the search results
note that this script does not download images, it just lets you view them
bandwidth issues
lets say you accidentally google-image-search the keyword beautybodybook
viewing the large format images of the search results
will consume about 26 megs ... nothing catastrophic
780 x 422 - 84K
Post edited by Cris Palomino on
  • mCasualmCasual Posts: 4,607
    edited August 2014
    the heart of the converter, in case you like reading code :)
    it'a a state machine!
    note that the daz forum robot deleted some of the code
    but the script on my site is not encrypted
    so you can see it there
    function convert( fi, fo )
     var file = new DzFile( fi )
     file.open( file.ReadOnly )
     var out = new DzFile( fo )
     out.open( file.WriteOnly )
     var state = 0
     while( !file.eof() )
      var str = file.readLine()
      var n = str.length
      var buffer = ""
      for( var i = 0; i < n; i++ )
       var c = str.charAt( i )
       switch( state )
        case 0:  if( c == 'i' ) ++state; else state = 0;break;
        case 1:  if( c == 'm' ) ++state; else state = 0;break;
        case 2:  if( c == 'g' ) ++state; else state = 0;break;
        case 3:  if( c == 'u' ) ++state; else state = 0;break;
        case 4:  if( c == 'r' ) ++state; else state = 0;break;
        case 5:  if( c == 'l' ) ++state; else state = 0;break;
        case 6:
         if( c != ";" )
          buffer += c;
         else
          buffer = buffer.replace( "=", "" )
          buffer = buffer.replace( "&", "" )
          oout.writeLine( "" )
          buffer= new Array()
          state = 0;
        break;
     file.close()
     out.close()
    Post edited by mCasual on
