How to make a Streetlight?
DekeDeke Posts: 1,635
I'm using Urban Sprawl to create a night scene. Great detail in the model and I'm using a spotlight pointed down from each streetlight. This creates a pool of light, but the streetlight itself has no glow. Is there a way to make the light glow? And maybe create a hazy funnel of light from it to the sidewalk below?
Thanks
  • arcadyarcady Posts: 340
    edited August 2014
    If you have Carrara you can just set a glow property on the object and then if rendering with indirect light it both glows and lights up the area.
    Carrara spotlights can also have volume effects (the hazy cone of light)
    In daz, you can put a bulb light inside the object and make the shader of the lightbulb mostly transparent. That will make it seem to glow.
    You can make volume spotlights with this tutorial:
    http://m.youtube.com/watch?v=umL5Fu--W8c
    Post edited by arcady on
  • macleanmaclean Posts: 2,438
    edited August 2014
    The quickest way is to use a lighter Ambient Color for the glass. It's not the most realistic effect, but it does help.
    For the funnel of light, try a cylinder primitive with high Ambient and some Opacity.
    mac
    Post edited by maclean on
  • DekeDeke Posts: 1,635
    Thanks I'll give those tricks a shot.
  • kaotkblisskaotkbliss Posts: 2,914
    The quickest way I've created light bulbs is by using the uberlights (sphere, beam etc.) then there's shaders you can apply to the light you already have that will do either smoke or dusty effect (although I haven't gotten those to work. I keep getting an error)
