I need quite a bit of help with daz studo 4.6
I have used daz studio for about 7 months now, i have gotten a little use to it, i got some stuff like hair clothes and figures etc and i dont dont where to put them, in what content or directories, i have put them in random spots and every time i open them up especially genesis 2 and other figures and objecs like clothes etc i get the message “Some assets needed to load the file were missing'' and it gets grey blocks instead, its been very stressful, genesis 1 works well,and one more thing every time i opern daz studio figures is all wide and stretched when i rotated the camera
293 x 294 - 23K
1342 x 684 - 334K
Post edited by 3Donga on
Look at my thread I just had the same thing and on page 4 I explain how I got it fixed but there are other suggestions from people before that you might try http://www.daz3d.com/forums/discussion/46006/
On the distortion, go to the Render Settings pane and check your size - I suspect your render size is set to be much wider than it is tall.
also for the missing files write down the location address it is looking for and then goto your library search for the file and copy and paste it to the proper location
I notice on the exe files for content that you just point it to the library directory and it will install it properly if it is a non exe file then open it up if it says something like content I go inside that folder until I see the folders data peopl runtime or whatever then copy and paste those folders into your library dir and you should be fine. daz has a way of seeing where everything is. I havent been able to find an organized structure for the files like poser has. maybe one day they will fix that and organize the file structure better
Thanks guys it all good now, the files where in public documents and my daz3d library, i have just a few more questions i got geneses 2 essentials all work good, then i brought Victoria 6 but it open up proper it comes up as a white figure any ideas ?? what i did was put it in with the geneses 2 female content in public documents.and in to daz3d library to the people folder.
Make sure you have installed the (free) Subsurface Shader Base: http://www.daz3d.com/subsurface-shader-base
I get that with gia all you need to do is go into materials and select a shader for her and she will be fine
thanks scott ill lok into that
