WTF? I need help?
LEE 6 + Future Wilderness Pants + UberEnvironment2 (w/environment sphere, park)
EDIT
Here's a dif image...
has a key light, spec light and the uber...
1280 x 480 - 275K
Post edited by ShawnBooth on
EDIT
Spec light only -
Key only -
Key/spec together -
Fill only -
backlight only -
Fill and backlight only -
All four lights -
All lights plus the UberEnvironment2 -
What am I doing wrong?
I adjusted my lights and dumped the uber for now...
ANY suggestions on tweaking the skin?
well with all those lights I would have used UE2 on about 30% intensity
As for the Skin what shader are you using?
Even with ONLY the UBER it's all screwed up though. The lights I went with are just standard lighting.
Honestly, not sure which shader, or how to tell... I have tried playing with settings with nothing good coming of it. I'm just not sure what is actually doing what.
Here's just the Uber, no other lights whatsever...
I upped the Occlusion Samples to 300...
This is just UBER -
First lets deal with UE2, Did you apply one of the presets to UE2 or just leave it White? And by the looks of your images it doesn't look like you applied a Quality Preset either. ;) Here is a great UE2 tutorial http://www.daz3d.com/forums/discussion/5320/
Next select the figure and go in to the Surfaces Pane, select a skin surface and look at the top of the pane it will tell you what the shader is. It could be AOA SSS shader but not having this figure I don't know. The first adjustment would be Specular and check to see if Reflection is off or at best really low. Given it will be a preset that comes with the figure I would say reflection will be OFF. But again I don't know. The other setting I would look at is Diffuse Strength, lowering it should help but it does depend on what setting it is on and adjusting it may have an effect on the Subsurface Scattering. If it is AOA SSS shader base then AOA has a nice Tutorial in the store you may want to get.
Occlusion samples only needs to be 128 max. Another thing to take a look at for Quality is in the Advanced Render settings, Shading Rate. When usinh UE2 this should be set to 0.20 or lower. Yes lower is better quality. This is not to be confused with UE2 Shading Rate, that doesn't need to be that low. Use the Quality Preset 4X in your Library and adjust the render setting and you should be fine for quality.
Here's my lights plus uber -
Okay - Thank you for the info. Let me apply your knowledge.
As for skin shader - I posted a pic of what is in there... Really have no clue though.
Based on your info -
I used this with UBER... No good?
Here's changing from the HDR KHPark to the 4XHi...
eh... Looks better with Park IMO -
As for skin shader - I posted a pic of what is in there... Really have no clue though.Ok but you didn't click on a skin surface to show what the shader is. :P See my image below. If you click on Skin it will select all the skin surfaces in one go and let you adjust them in one go.
It is AoA_Subsurface...
Park is the Light Preset which applies a light map to UE2 and 4 x is the quality setting so use both. ;) Now lower the light intensity of UE2 to 30%.
UE2 is what we call Image Base Lighting (IBL) which uses a map (image) to light your scene. It extracts lighting information from the map so different maps will give different lighting. The Park preset has a bright spot representing the sun, blue sky and green grass. So you will get a white light from the sun, blue from the sky and green from the grass.
Got it. Thank you so much for your help. I'm gonna have to check that tut out.
It is AoA_Subsurface...Ok now look for the Specular channel as see what setting it is on. Try lowering it and test but if it is low already then try lowering the Specular light instead. Most of the time when making scenes you will need to adjust either lights or surface or both. There is no one set of settings that will suit every figure or scene. Yes a lot of test renders to be done. But as time goes by the number of tests you do should diminish.
Got it. Thank you so much for your help. I'm gonna have to check that tut out.my pleasure and yes check it out as it is worth it. But trust me don't try a learn about it all in one go. There is a lot to take in and may addle the brain. :) I was there once and it took me a bit to get my head around it all.
Ok since it is now 3.30 AM I am off to bed. So any more q's I will answer them tomorrow, unless someone else steps in. I also have a few tutorials listed in my render thread (link in my sig) that you might want to take a gander at a later date.
I'm very much aware that settings vary per scene/project/etc. I'm just new to 3D and trying to get a grasp of things. For example, SSS - I have no clue where to begin but I keep playing with it.
Finally achieved something I really like (skin wise). Thank you for your assistance -
I would recommend you render from each of the lights. Take them to Photoshop and layer them over each other. You can do a base layer of black. Set all layers to screen. Now you can play with the blend modes, opacity, etc, and have greater control over the lighting from each of the lights. This includes lights set only to specular, etc. You can even intensify light by doubling a layer or using a layer mask to add or delete from specific areas.
Mahalo Chris - I'm actually playing with that technique now :)
