Replacing textures
I often create my own texturess but have to load them manually using the "Surfaces" tab.  Is there a way to load them by simply clicking on pre-purchased textures.  Showing them in the Daz database.
  • LeanaLeana Posts: 11,737
    Once you've applied the texture manually the first time you can save a material preset or shader preset for next time.
    You could also make a copy an existing preset for your target surface and use a text editor to change the path to the textures used in the copy.
    If you often have to load multiple maps there's also this: https://www.daz3d.com/multi-map-loader
  • Gonna give that a shot.  Thank you!
