Figure rotation question
Choppski
Sometimes when I apply a pose to a figure, the figure's y axis rotation changes. Instead of pivoting around its center, it does this huge circle. Is there a way to change that or return it to normal?
That is because the hip has been translated, so it is distant from the figure node (which is what you ar then seelcting to apply the rotation). Poses should not do that, unless they need it as part of a group pose (e.g ship's crew) - if it is in a daz set please report it. In the meantime, move the hip back to the figure node and you can use them together as intended (ideally the hip should be adjusted only as much as is needed and major adjustments, such as scene placement, should be handled by the figure node).
Thank you.
