is there a way to change the names of the material fields in surface tab?
  • felisfelis Posts: 4,348
    It you select the Geometry Editor amd open Tool Settings, you can rename surfaces there.
  • VicSVicS Posts: 1,273
    thanks felis
  • frank0314frank0314 Posts: 14,070
    Be aware that if you do that it's possible it can screw up several things that you will end up needing to fix
  • To clarify on Frank0314's post, if you're working with pre-made content, material presets will no long work with the asset.
    If you're developing your own, the same will apply with any presets generated before the change.
    so best not to fool with them sounds is what I'm understanding, thanks
