G8Figure Surface Broken re-install doesn't fix HelpPlz
shawn_2093844fdbshawn_2093844fdb Posts: 4
edited March 2023 in Daz Studio Discussion
I keep my content in separate categorized libraries thinking if I break something I'll only affect that content, however I somehow broke Gertha and some other G8F characters as well.  Note* Gertha worked fine for the first day, I even exported subscenes with her associated files to keep my content size down and those are now bad after the fact. Re-installing DAZ and the G8 essentials fixed G8 and the other characters but when I apply a fresh install of Gertha the surface is broken. Attached is a side-by-side of the settings.  G8F on the left, Gertha Applied in the middle, on the right is Gertha after copying G8F surface in an attempt to fix. I can get most of Gertha skin usable with the copy-paste-surface but I still run into this issue with parts of here that the surface is still broken (pic2) such as between the forehead and hair. I'm on a fresh daz install (deleted all the associated files after uninstall, updated geforce drivers, the log has nothing that stands out that wasn't dismissed in the multitude of other posts I researched. Any gurus with some insight?
3M
963K
Post edited by shawn_2093844fdb on
    Gertha is a Genesis 8.1 character, so she may well use the genesis 8.1 Female UVs and the PBRSkin shader, while Gensis 8 Female does not have the 8.1 UVs and does not use the PBRSkin shader for the base materials, so copy/paste of settings will not give an exact match.
  • shawn_2093844fdbshawn_2093844fdb Posts: 4
    edited March 2023
    So Gertha is listed as 8 and 8.1, but i've tried with both and the issue persists.
    Oh s*jt I can't believe I missed that. Some of the other characters that got corrupted last night had the choice between 8 and 8.1 and I was troubleshooting them all on the G8 model but after reinstalling and resolving those I kept missing that gertha was 8.1 which explains why it's the last character that wouldn't get fixed. Any idea how I could have corrupted the base Genesis 8 by dropping a couple new clothing items in a separate content library and I may have added another character or two but again all of which is in a separate content library from the essentials and the base Genesis models?
    edited March 2023
    I'm not sure if this information helps at all but after my clean install, (uninstalling, deleting MyDocs../DAZ 3D, deleting C:\DAZ 3D, deleting the ProgRa and x86 DAZ folders, after a clean install my layout and toolbars are still customized. Also notable but I'm not 100% sure, I feel like G8F and G8.1F default characters are showing up with a deeper red hue than they did before last night. Last bit of insight, before my re-install I was getting a couldn't find DTHDR-RuinsB-500.hdr which I read is an iray setting file but that's been resolved with the install.
     [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "G:\DAZ 3D _ESSENTIALS\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    Layouts are kept in the Appdata folder, soem settings in the Registry (or Mac equivalents).
