Genesis 8 Model Deformation Is Perplexing (and Unpleasant)
sentientblobsentientblob Posts: 11
My G8 Models are experiencing strange deformations at the bend points and I'm wondering if there's a setting I may have inadvertently activated.  I've attached a video wherein I load a fresh G8F model and the results are plainly obvious by the time the bend is around the 75% mark.  Any advice/help would be appreciated.
Example: link removed
  • Richard HaseltineRichard Haseltine Posts: 101,032
    The link would have been fine if you had left it in wire shaded style.
    That looks as if there is either a morph in effect that lacks joint adjustments or a joint adjustment without its matching morph applied - either way, the centres of rotation do not line up with the placement of the shape's joints. Does Edit>Figure>Zero>Zero Figure Shape remove the effect?
  • You were right, it was a morph.  I disabled all of them using the Turbo Loader extension and was able to figure out what was wrong and reconfigure the preset values for that software.  Works like a charm now.  Thanks for the tip!
