Pointlights not behaving
Ok, so I came up with a nice scene. Started the lighting process(its never click and go...is it?)
Had a nice set-up, but needed just a 'touch' of illumination in a particular spot to get rid of some noise. Created a point light, turned it down, positioned it, and it looked good. Did what I needed...EXCEPT...it was casting shadows. So I double-checked the tab for it, "shadow type-none"
Go back in, double check all the lights(not many there is 4 total) I am getting fairly good shadows from the spotlight above her(just nothing from the hair oddly). But the one point light I have to touch up this spot, is casting shadows when its not suppose to.
How do I fix this?
  • Richard HaseltineRichard Haseltine Posts: 101,032
    In 3Delight or Iray? In Iray lights always cast shadows (in Photoreal mode) - if you are seeing the Shadow Type property you must have Preferences>Show Hidden Properties on in the pane's option menu.
