mouth gets distorted when trying to convert from g8m to g3m
hi im tryin to convert Archdemon HD for Genesis 8 Male to genesis 3 male but the mouth gets distorted and really wired looking
im using transfer utility
can someone please help?
  • Catherine3678abCatherine3678ab Posts: 8,344
    No, the HD morphs 'we the people' cannot transfer between the Genesis figures. Only PAs can as they have access to another tool required for that task.
    An awful lot of work would have gone into that figure, requiring undoubtedly all kinds of what I call 'fix-it' morphs, so it will work correctly on the figure it is intended for.
    What I would suggest doing is using that character with G8M and then go into the Hidden morphs [Parameter Tabs with show hidden toggled on] and dial in some of Genesis 8 female. See how that works for you.
  • m300m300 Posts: 25
    edited July 2023
    i toggled the show hidden ptoperties but all i see is JL_ADHD_BoneOffset dont know what that is
    "dial in some of Genesis 8 female" what do you mean by that? is is a male figure
    Post edited by m300 on
  • Richard HaseltineRichard Haseltine Posts: 101,032
    Distorted how? Is this happening when the figure is unposed, or only when a pose is applied?
    Genesis 8 Female is included as a "clone" for G8M. The reverse is also true. Look for it in the Hidden section, under Clones IIRC.
    edited July 2023
    i can't show how it looks like since attaching one picture gives me infinite Uploading...
    but basically it looks like it didn't convert the teeth and mouth, also the mouth is open so maybe thats the reason but it looks bad
    i don't think it's the pose since it's only happens with the mouth and teeth the rest of the body looks fine
    But is it happening with posing? If so the bones for the jaw probably need adjusting to shape.
    i did adjust the posing of g3 to g8 but that's it then i use the transfer utility like i always do never had a problem until now
    even if i do need to adjust the jaw how do i do that?
    The Joint editor can be used to mode the centre/endpoints of bones, or there is Edit>Figure>Rigging>Adjjust Rigging To Shape.
