How to change a G9 figure shape to default G9 shape ?
Hi, so I'm trying to apply some shape preset to Julia 9 but it just turns out ugly. I figured it might be cause of the shape which comes pre-baked with the figure and unfortunately there's no "Remove Body" or "Remove Head" option. What should i do in this case ?
  • Load the default figure in the first place. Then one can mix 'n match the various morphs in the gene pool. When a suitable combination is discovered, select the figure and save out a Shape Preset. When the option dialogue presents, first uncheck the root figure. Then right-click and select the option to select all that were changed. You might want to double-check what has been selected, adding or deleting a few before accepting.
    edited August 2023
    Go to Parameters pane, select Currently Used, filter "Julia" then tweak the vlaues of the morphs.
    Post edited by crosswind on
    Yup, it worked. Thanks a lot ❤️
