DIM will not install daz studio
I'm trying to get Daz Studio set up on a new computer. I've installed DIM, run it, and logged in. It informs me that it wants to install a big pile of things, including Daz Studio itself. Everything else (assets and tutorials) installs fine, but Daz Studio doesn't install. It just sits there in the "ready to install" tab with a big red "retry" button. Clicking it makes DIM think for a moment, then go right back to where it was. No error message, nothing. I've tried deleting the package and re-downloading it, but the same thing happens.
What should I to do troubleshoot this? I'm kind of stuck.
  • SofaCitizenSofaCitizen Posts: 1,896
    edited September 2023
    Pretty sure that's an OS permission thing, but I cannot remember the fix for it off the top of my head. What OS are you running?
    There is a cog icon in the top right, click that and check the two logs in there and there will probably be an error message.
    Post edited by SofaCitizen on
  • Both newer Macs and newer versions of Windows default to modes that are very restrictive about what they will install. In macs you will, at least, need to tell gatekeeper to allow DIM/DIME Helper to run; in Windows 11 you will need to switch off the Windows S mode which limits instalaltion to items from the MS store.
    Thank you for the reply! I really appreciate it.
    I'm running Windows 11. Sorry, should have said initially.
    I checked, and I don't see anything that explains it to me, but I'm way over my head here.
    ------ the last bit of log.txt
    2023-09-15 18:36:07.948 +++++++++++++++ Install Manager 1.4.1.62 starting +++++++++++++++++
    2023-09-15 18:36:07.948 [INFO] :: OS bits: 64
    2023-09-15 18:36:07.948 [INFO] :: Platform bits: 64
    2023-09-15 18:36:07.948 [INFO] :: Qt Version: 4.8.7
    2023-09-15 18:36:07.948 [INFO] :: Running on Windows 11, Build 22621, Workstation
    2023-09-15 18:36:07.948 [INFO] :: Physical Memory:
    2023-09-15 18:36:07.948 [INFO] ::     Total: 63.7 GB (68477960192)
    2023-09-15 18:36:07.948 [INFO] ::     Avail: 54.7 GB (58744340480)
    2023-09-15 18:36:07.948 [INFO] :: Virtual Memory:
    2023-09-15 18:36:07.948 [INFO] ::     Total: 127.9 TB (140737488224256)
    2023-09-15 18:36:07.948 [INFO] ::     Avail: 127.9 TB (140732931059712)
    2023-09-15 18:36:07.948 [INFO] :: Current Memory Usage: 14%
    2023-09-15 18:36:07.948 [INFO] :: Current DateTime:
    2023-09-15 18:36:07.948 [INFO] ::     Loc: Fri Sep 15 18:36:07 2023
    2023-09-15 18:36:07.948 [INFO] ::     UTC: Sat Sep 16 01:36:07 2023
    2023-09-15 18:36:07.948 [INFO] :: Home Path:
    2023-09-15 18:36:07.948 [INFO] ::     Location = C:/Program Files/DAZ 3D/DAZ3DIM1
    2023-09-15 18:36:07.948 [INFO] ::     Disk Total: 1.8 TB (1999593533440)
    2023-09-15 18:36:07.948 [INFO] ::     Disk Avail: 1.4 TB  (1637576486912)
    2023-09-15 18:36:07.948 [INFO] :: Application Data:
    2023-09-15 18:36:07.948 [INFO] ::     Location = C:/Users/maeke/AppData/Roaming/DAZ 3D/InstallManager
    2023-09-15 18:36:07.948 [INFO] :: Locale: en_US
    2023-09-15 18:36:07.948 [VERBOSE] :: Translator Not Found: ./language/en_US
    2023-09-15 18:36:07.948 [INFO] :: Reading dzInstall.ini...
    2023-09-15 18:36:07.949 [INFO] :: Current Account: Account
    2023-09-15 18:36:07.949 [INFO] :: Current Downloads Path:
    2023-09-15 18:36:07.969 [INFO] ::     Location = J:/Daz Assets/Downloads
    2023-09-15 18:36:07.969 [INFO] ::     Disk Total: 7.2 TB (8001544777728)
    2023-09-15 18:36:07.969 [INFO] ::     Disk Avail: 3.8 TB  (4268649799680)
    2023-09-15 18:36:07.969 [INFO] :: Current Content Install Path:
    2023-09-15 18:36:07.969 [INFO] ::     Location = J:/Daz Assets/My DAZ 3D Library
    2023-09-15 18:36:07.969 [INFO] :: Current 64-bit Software Install Path:
    2023-09-15 18:36:07.969 [INFO] ::     Location = C:/Program Files
    2023-09-15 18:36:07.969 [INFO] ::     Disk Total: 1.8 TB (1999593533440)
    2023-09-15 18:36:07.969 [INFO] ::     Disk Avail: 1.4 TB  (1637576482816)
    2023-09-15 18:36:07.969 [INFO] :: Current 32-bit Software Install Path:
    2023-09-15 18:36:07.969 [INFO] ::     Location = C:/Program Files (x86)
    2023-09-15 18:36:07.969 [VERBOSE] :: Thumbnail Max Height: 182
    2023-09-15 18:36:07.969 [INFO] :: Starting CMS...
    2023-09-15 18:36:07.970 [WARNING] :: CMS Connection Failed: Cannot be started by client.
    2023-09-15 18:36:09.784 [VERBOSE] :: Logging in...
    2023-09-15 18:36:11.762 [VERBOSE] :: Logged in
    2023-09-15 18:36:11.763 [VERBOSE] :: Checking session ID validity...
    2023-09-15 18:36:11.842 [VERBOSE] :: Session ID valid
    2023-09-15 18:36:11.842 [INFO] :: Requesting product information: 50873...
    2023-09-15 18:36:12.207 [INFO] :: Received product information: 50873
    2023-09-15 18:36:12.208 [INFO] :: Application update not detected
    2023-09-15 18:36:12.213 [INFO] :: Current Account: Account
    2023-09-15 18:36:12.213 [VERBOSE] :: Thumbnail Max Height: 182
    2023-09-15 18:36:12.213 [VERBOSE] :: Checking session ID validity...
    2023-09-15 18:36:12.395 [VERBOSE] :: Session ID valid
    2023-09-15 18:36:12.395 [VERBOSE] :: Requesting remote package data...
    2023-09-15 18:36:12.395 [VERBOSE] :: Requesting current notification data...
    2023-09-15 18:36:12.395 [VERBOSE] :: Requesting default notification data...
    2023-09-15 18:36:12.396 [VERBOSE] :: Begin processing package archive...
    2023-09-15 18:36:12.463 [WARNING] :: 11496-1 : Supplement tags missing.
    2023-09-15 18:36:12.584 [VERBOSE] :: Finished processing package archive: Elapsed Time 0 min 0 sec 187 msec
    2023-09-15 18:36:12.584 [VERBOSE] :: Begin cleaning package archive...
    2023-09-15 18:36:12.584 [VERBOSE] :: Finished cleaning package archive: Elapsed Time 0 min 0 sec 0 msec
    2023-09-15 18:36:12.584 [VERBOSE] :: Begin processing manifest archive...
    2023-09-15 18:36:12.832 [VERBOSE] :: Finished processing manifest archive: Elapsed Time 0 min 0 sec 247 msec
    2023-09-15 18:36:12.832 [INFO] :: Installed Packages: 2593 : 473.0 GB
    2023-09-15 18:36:12.863 [VERBOSE] :: Local cache contains default notification data
    2023-09-15 18:36:12.863 [VERBOSE] :: No resources referenced by current notification
    2023-09-15 18:36:12.863 [VERBOSE] :: Received current notification data
    2023-09-15 18:36:13.311 [VERBOSE] :: Received remote package data: Elapsed Time 0 min 0 sec 915 msec
    2023-09-15 18:36:13.316 [VERBOSE] :: Begin processing remote package data...
    2023-09-15 18:36:13.318 [VERBOSE] :: Finished processing remote package data: Elapsed Time 0 min 0 sec 2 msec
    2023-09-15 18:36:13.318 [INFO] :: Remote Products: 36
    2023-09-15 18:36:13.318 [INFO] :: Remote Packages: 86
    2023-09-15 18:36:13.318 [VERBOSE] :: Begin processing serial number data...
    2023-09-15 18:36:13.318 [VERBOSE] :: Finished processing serial number data: Elapsed Time 0 min 0 sec 0 msec
    2023-09-15 18:36:13.325 [VERBOSE] :: Evaluating Default Install Module...
    2023-09-15 18:36:13.325 [VERBOSE] :: Install set "DAZ Studio" has potential
    2023-09-15 18:36:17.871 [VERBOSE] :: Begin processing actions...
    2023-09-15 18:36:17.871 [VERBOSE] :: Finished processing actions: Elapsed Time 0 min 0 sec 0 msec
    2023-09-15 18:36:17.902 [VERBOSE] :: User accepted install sets
    2023-09-15 18:36:17.985 [INFO] ::     Json Parser (1,1): Syntax error - expected '{' or '['
    2023-09-15 18:36:17.991 [INFO] :: Installing: 13176-2 : DAZ Studio 4.21 (Win 64-bit)
    2023-09-15 18:36:21.695 [WARNING] :: QProcess: Destroyed while process is still running.
    2023-09-15 18:36:21.700 [WARNING] :: Install Failed: DAZ Studio 4.21 (Win 64-bit)
    2023-09-15 18:36:21.701 [INFO] :: Install Queue Finished: 0 min 3.7 sec
    ---the last bit of helper log (hlog.txt)
    2023-09-15 18:36:21.686 +++++++++++++++ Install Manager Helper 1.4.1.62 starting +++++++++++++++++
    2023-09-15 18:36:21.686 [INFO] :: OS bits: 64
    2023-09-15 18:36:21.686 [INFO] :: Platform bits: 64
    2023-09-15 18:36:21.686 [INFO] :: Qt Version: 4.8.7
    2023-09-15 18:36:21.686 [INFO] :: Running on Windows 11, Build 22621, Workstation
    2023-09-15 18:36:21.686 [INFO] :: Physical Memory:
    2023-09-15 18:36:21.686 [INFO] ::     Total: 63.7 GB (68477960192)
    2023-09-15 18:36:21.686 [INFO] ::     Avail: 54.6 GB (58653016064)
    2023-09-15 18:36:21.686 [INFO] :: Virtual Memory:
    2023-09-15 18:36:21.692 [INFO] ::     Total: 127.9 TB (140737488224256)
    2023-09-15 18:36:21.692 [INFO] ::     Avail: 127.9 TB (140732957741056)
    2023-09-15 18:36:21.692 [INFO] :: Current Memory Usage: 14%
    2023-09-15 18:36:21.692 [INFO] :: Current DateTime:
    2023-09-15 18:36:21.692 [INFO] ::     Loc: Fri Sep 15 18:36:21 2023
    2023-09-15 18:36:21.692 [INFO] ::     UTC: Sat Sep 16 01:36:21 2023
    2023-09-15 18:36:21.692 [INFO] :: Home Path:
    2023-09-15 18:36:21.692 [INFO] ::     Location = unknown
    2023-09-15 18:36:21.692 [INFO] :: Application Data:
    2023-09-15 18:36:21.692 [INFO] ::     Location = C:/Users/maeke/AppData/Roaming/DAZ 3D/InstallManager
    2023-09-15 18:36:21.692 [INFO] ::     Disk Total: 1.8 TB (1999593533440)
    2023-09-15 18:36:21.692 [INFO] ::     Disk Avail: 1.4 TB  (1637576085504)
    2023-09-15 18:36:21.692 [INFO] :: Helper application data path: C:/Users/maeke/AppData/Roaming/DAZ 3D/InstallManager
    2023-09-15 18:36:21.692 [INFO] :: Starting CMS...
    2023-09-15 18:36:21.692 [WARNING] :: CMS Connection Failed: Cannot be started by client.
    2023-09-15 18:36:21.699 [INFO] :: Current Content Install Path:
    2023-09-15 18:36:21.699 [INFO] ::     Location = J:/Daz Assets/My DAZ 3D Library
    2023-09-15 18:36:21.699 [INFO] ::     Disk Total: 1.8 TB (1999593533440)
    2023-09-15 18:36:21.699 [INFO] ::     Disk Avail: 1.4 TB  (1637576085504)
    2023-09-15 18:36:21.699 [INFO] :: Current 64-bit Software Install Path:
    2023-09-15 18:36:21.699 [INFO] ::     Location = C:/Program Files
    I don't believe I am in S mode.  Settings > System > About -> "windows specifications" doesn't say anything about S mode, which is what the MS support page says I should look for.
  • I tried uninstalling DIM, and removing the "c:\users\public\documents\daz 3d" folder that I have been told daz puts some settings in, for a fresh install...and now I'm even worse off. Now Daz Studio AND PostgreSQL are both refusing to install.
  • I was able to solve the problem, somehow. A complete uninstall of daz, followed by also manually removing appdata\roaming\daz 3d AND users\public\documents\daz3d AND rebooting seems to have worked, and now I can use the software.
    I have questions about how to get my old UI back, but that is probably a matter for a different thread. Thank you!
  • Sorry for not replying but I went to bed after posting. However, I think Richard added the detail that I was missing - although like you, my version of Windows doesn't refer to it as S mode specifically but I do have Apps > "Advanced app settings" > "Choose where to get apps" set to "Anywhere" which seems to be the same thing with a different name. I miss the old control panel :(
    Just to add an additional thing which might explain why your "delete everything and start again" method actually worked could be the presence of "Json Parser (1,1): Syntax error - expected '{' or '['" in the log. That usually happens with a corrupted download from Daz Connect rather than via DIM but the end result would be the same in that something didn't quite download correctly the first time and so it was falling over when trying to read it.
  • AscaniaAscania Posts: 1,849
    Or you specify an installation directory that's not in the default Programs folder to get around it.
    That was my thought, but deleting the package and re-downloading it didn't fix it. Though I suppose it could have had a config file or something that it kept around, with the error.
