Diffeomorphic Import morphs not working
bayrayart
I'm not sure what is going wrong here,
I am using blender 3.6.11, I updated diffeo.
I have XY morphs working in Daz. I import following guidelines from the tool devs.
I imported both daz favorites (favoriting relevant morphs), and manually adding morphs. However the shape keys are not working correctly. I bet there's just some simple step I'm missing.
If you could DM me on discord, raybayb, that would be nice, but otherwise I look forward to responses here. Thank you!
Post edited by bayrayart at
In general there are limits in what diffeomorphic can import, not all the daz morphs work fine. Especially with scaling there are issues as blender doesn't support scale maps. One way to get around the issue, if we really need a specific morph which doesn't work, is to import as dbz morph.
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs/Import DBZ Morphs
Then I have no idea what the "shake keys" are, if you need to investigate the issue further I suggest to use bitbucket, where Thomas can give it a look. Also due to the daz rules this is not the best place to deal with genitalia geografts.
https://bitbucket.org/Diffeomorphic/import_daz/issues
I assume that he meant shape keys...
I meant shape keys, woops!
Thank you, I got it working this way :) Also thank you for pointing me to the right spaces for more information
