Scene Info window/tab can't do simple addition? (Solved)
It says one scene has 1,627 verts.
So I put another copy of everything in the scene into the scene, and add yet another object to boot.
Then it says the scene has 2,976 verts. That is less than double the original amount. Why?
Post edited by lukon100 on
If you correctly loaded the very same subset or 100% duplcated the selected items, the vertex count should be correct, i.e. x2 ... Maybe you can check the items again.
Anythng instanced?
Nope:
Cut to the chase: you can download my free model and see for yourself what I'm talking about.
The dowload features 2 scene subset assemblies: the single and the double. Contrast the vertex count between them and see for yourself.
https://www.renderhub.com/lukon/observation-deck-tetrapoint-base-v1
You are not duplicating the elevator
Yes! Thanks so much, Omniflux!
