[FIXED] Pointed elbow
Genesis 8/8.1 Males have developed an elbow issue in my installation. Both sides look normal in the default pose, but the elbows on both sides protude when the forearm is bent, as shown in the attached picture. It looks painful!
I have been uninstalling and reinstalling character packages and messing with TurboLoader for most of the day and nothing has fixed it.
Does anyone know what could be causing this issue to help me narrow down my tests?
Thank you.
2134 x 964 - 376K
Post edited by fullerdb on
Apply the least posing you can get away with trigger the issue (probably just bend the elvbow on an othrwise zeroed figure), in the Parameters pane option menu (the lined/hamburger buton in the top corner) enable Preferences>Show Hidden Properties, and with the figure selected look in Currently Used - with luck one of those is the issue, if you find one that clears the problem when zeroed then click the gear icon on the slider and open Parameter Settings, then look at the asset details to see what is responsble. I wouldexpect it is a corrective morph for a character or shape that should be triggered only when the shape is, but it instead applying at all times.
Thanks, Richard!
I had tried to look in Currently Used, but I had been unable to identify the source of the problem because some names were too generic. Actually going into the Parameter Settings through the gear icon let me find out that the source of the problem was this cute fella: https://www.daz3d.com/ceremony-hd-for-genesis-8-male. I had partially disabled it using Turbo Loader, so it is not the product's fault. I batch-disabled a bunch of things yesterday and it must have been a misclick.
Anyway, thanks again for the nudge I needed to find the issue!
