Message Shirt Magic Not Working
Hey. everyone who knows Message Shirt Magic. Here's the issue: I can load the wardrobe items but the customizable text and colors stopped working. I uninstalled and reinstalled everything, but it still doesn't work. Any ideas?
#3DU
  • murgatroyd314murgatroyd314 Posts: 1,549
    I had a similar issue a while back, but I'm afraid I can't really help. It fixed itself one day, just as mysteriously as it broke.
  • felisfelis Posts: 4,682
    Maybe some more information on your process.
    Is the script running?
    What does your log (Help > Troubleshooting > View Log) say when you try?
  • tached
    Thanks. I attached a screen shot of the error message. I get a series of those the only difference being which png file it can't find-- front, back, trim...etc...
    504 x 104 - 10K
    It is a weird path it is using for the files.
    How have you installed it?
    Have it worked previously?
    Have you moved your content library?
    Those look like Daz Central root paths, then it is placing the resources in the application folder - did you get a UAC prompt when installing?
    It worked fine for quite awhile. Then, it stopped working. I uninstalled and re-installed using Daz Install Manager. Daz does find the wardrobe items but just can't use the customization features.
    I didn't get any prompt. I Clicked on Download in the Install Manager and it downloaded and then installed it.
    I am not sure whether UAC would protect a non-standard application folder - though DIM should be trying to run anything that installs "like software" through DIMHelper, with elevated permissions, so the permission eelvation ought to trigger UAC regardless of destination folder.
    Thanks!
