Redacted
cridgit
Redacted
Post edited by cridgit on
Redacted
dpc.exe - pc would be the poser file for non-mac.
a zip file with the IM prefix, like IM00000882_little-french-maids.zip, seems to include all the install files.
i haven't d/l the trx files, i'm guessing it's for the ds content manager service. poser doesn't seem to need it.
some of the files don't come with the readme's, meaning no file list. these dayz i install to a temp folder first so i can see what files are installing.
trx is often, but not always Genesis content (trx stands for Triax Weight Mapping), but sometimes DS materials as named trx as well. Content manager files are named Metadata but newer installers has the metadata built in and not in a senarate installer, good as it feels like overhead to download 15MB installer to install a 2k file...
Redacted
Could be as simple as someone not understanding the naming convention.
The theory is: new releases include metadata in the main installer; older releases include metadata as a separate installer, unless they have been updated recently, in which case the metadata has been moved into the main installer; pre-DS 4 releases don't have metadata unless they've been updated. Metadata should only ever be in one installer, so if there's a separate metadata installer you do need it.
Redacted
That's what I thought too, but I've been checking by installing only the main installer for products with separate metadata installers and half the time the metadata is installed too. The other half I need to use the separate metadata installer.
Which ones? I haven't found any products which had separate metadata installers which didn't also have the metadata in the main installer.
Redacted
I haven't kept a list Mike, but about a dozen or so over the past 2 months. From my installer archive, I'll go look up which metadata files I kept, which means they were needed at the time of installation. If the main installer works I chuck the metadata installer.
I'll post back when I've made the list - it'll be a search on a huge non-indexed NAS drive.
EDIT: what I have so far (about to go to bed so will update tmw)
- Dream Home Yard & Pool
- Carnival Picnic Tables
- Sports Time for Genesis
- Real Tanks & Containers
What version numbers? I just installed Carnival Picnic Tables and Real Tanks & Containers, both were version 1.1, and both had the metadata in the main installer.
Redacted
I think you neglected to mention that the only way to determine relative sizes is to completely download both files.
(Come on, DAZ! Every server on the entire internet except yours tells my browser how large the file is at the start of the transfer.)
Whats really sad is on the download page the space taken up for the amount of downloads you have left when there is more than enough room to list the size of the file.
