Bryce 5 content
Ali BozisAli Bozis Posts: 39
Where do i install these files. When I install them under (C:\Program Files (x86)\DAZ 3D\Bryce7\Presets) they dont show up in bryce ? So how do I make them show?
634 x 377 - 85K
  • Dan WhitesideDan Whiteside Posts: 500
    edited October 2012
    Bryce doesn't use external content - it's all internal to Bryce and that's where it's loaded from.
    After you unzip each file (they can go anywhere) if they have an extension of:
    .OBP - click the little triangle next to the word "Create" (top of Bryce interface), select a category, select Import and navigate to the .OPB file, Hit OK.
    .MAT - triangle next to "Edit"
    .BSK - triangle next to "Sky&Fog;"
    .BR extension are scene files and are accessed with the File>"Open" menu item.
    HTH;
    Dan
    Post edited by Dan Whiteside on
  • HoroHoro Posts: 10,555
    I have a document that explains it all on my website (see sig). Go to Bryce Documents > Mine > Diverse > Bryce Content FAQ or click on this link http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf to get the 11 page 590 KB PDF.
    Talking of content. I haven't installed Br 6 on the new PC, but did try to install the Br 6 bonus content pack, which refuses to run because I don't have Br 6 on the PC. It doesn't appear to have any option in the installer to put it anywhere else, so I can't run it to an empty folder.
    Any ideas how I can make the installer run.
    edited October 2012
    Hard to believe - I have never had problems installing content where I wanted it. I have a Bryce 6 Content DVD and there is not even an installer. Just the files in their respective folders.
    Post edited by Horo on
    Generally speaking installers can be fooled into releasing their goods if you either copy/paste/rename a safe .exe file into the folder where you want the goods planted. With some installers one can even just make a fake .exe file using a text editor - i.e. Notepad, which will permit a "save as" "all file types", and manually add the point exe to the end of the name. Just be sure to delete the fake .exe afterwards!
