How Do You Remove Z Translation From Animations In DAZ Studio
Hello All,
I would like to know if there is a method of removing z translation from an animation in DAZ Studio.
I can't seem to figure out how to set all of the keyframes to have a z translation of zero. I tried using the animate tab, as well as baking the animate block to studio keyframes. I was only able to set each keyframe to have z translation 0 one at a time.
I was wondering if there is a way to set them all at once?
Thanx to any who might help.
  • carolinebegbiecarolinebegbie Posts: 162
    Within aniMate2, you can use the graph editor to remove the z translation.
    If you have baked to Studio keys, select the joint to remove z translation (usually the hip), then Alt+click on the Z translate slider.
    To delete inside aniMate2:
    The graph editor is the icon highlighted on the right.
    Click the pos_z on the hip, then click the - key icon, and delete all keyframes in the block that way.
    757 x 246 - 27K
