i cant install 14812_GenesisStarterEssentials_1.6_trx
taurusate9taurusate9 Posts: 0
i dont know what to do i click it but it doesn't open
    It could be thhat maybe you have an incomplete download ? What size is the file you have downloaded.
  • taurusate9taurusate9 Posts: 0
    i think 461.6 mb to be exact 461.590.164 bytes
    I am trying to find you some help
    also having problems with BryceProContent_7.0.0.19_Mac 25.8 mb and BryceContent_7.0.0.19_Mac 606.6 mb
    Ugh, you are on a MAC. OK, I shall go find someone else.
    As regards Bryce, the content pack for a PC weighs in at 670 mb and the smaller one at 26.7 mb.
    BTW what OS X are you using. If it is OS X 10.7 then you will be out of luck with Bryce, because it is currently not working under Lion. It does say that on both the product page and the tech specs.
    10.6.8
    Ah, right so you should be fine with Bryce, I just need to find a Mac Brycer to help you, what exactly is the problem you are having with the Bryce content, is it just knowing where to put it, or something else.
    If it's just where to put things, this may help you
    http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf Done by one of the Bryce gurus
    I shall now go and see if I can find the Guy who may be able to help you with Your Snow Leopard installation of DS.
    i just cant install those things i click on them but they dont open
  • TotteTotte Posts: 14,088
    Hello,
    Couple of questions.
    How did you expand those installers (the zips)? Did you use Safari's built in "Open safe files" or did you unzip the yourself from Finder?
    When you click on the does it try to start? And if you start "System messages" found in Applications/Tools, do you see any error messages from the installers?
    Need to establish where and what before I can say "how".
    Cheers,
    / Totte
    i used an app called winzip mac yes it tries to start and no there are no error messages
    Don't!
    Most third party unzippers ruins the installer as the installer has zip archives internally that the external unzippers also unzip for you, which makes the installer useless. Always unzip installers with Apple's own unarchiver, it does what it's supposed to do, without ruin the installers.
    / Totte
    thank youuuuuuuuuuuuuuu
  • adamr001adamr001 Posts: 1,322
    This file size is off. Something is wrong somewhere.
    I just redownloaded it to verify and 14812_GenesisStarterEssentials_1.6_trx.zip is 434mb (455,271,178 bytes)
    totte got it
  • f_ehlersf_ehlers Posts: 3
    Where can I find the GenesisStarterEssentials_1.6_trx.EXE file
    ((I don´t want to use DIM))
    Thx
    edited October 2013
    Thx
    Your Product library. Go to your account (top right of the page) and click on product Library from the top line, search for DS 4.6
    703 x 450 - 244K
    Post edited by Chohole on
