Puppeteer Panel
Is there a way to lock the Puppeteer Panel so it stays visible on the Pose/Animate window when you select another figure and then return to the original. I want to use camera and light puppeteer panels as well as my main figure puppeteer. I have tried the always on top on and off on works as long a you don't select another figure..
Post edited by Oldminer on
Redacted
I think, it depend on what type layout you use. but about every layout, you can customize easily,
eg when you select ,"pose /Animate"activity , you want to show and fix the "puppeteer" in one of contena?
you just drag the puppeter window(tab) to the contena where you want .
or mergin area of each contena (tabs), right click, then select "Add pane"
choose "puppeteer"
and you want to save the layout, on top menu window>work space>save layout eg "animattion layout"
Thanks all, I got what I needed and can now dock the Puppeteer panel as needed and your right this solves keeping it available.
