Display Property Group in the Parameters tab?
![Cayman Studios](https://delorean.daz3d.com/forums/uploads/userpics/407/n3JQ5QNW11IBV.jpg)
I cannot find a way of selecting and displaying a Property Group in the Parameters tab. I can change the values of the properties themselves, and I can get the Parameters tab to display using "togglePane", but I cannot get a group (say, Actor/People/Real World) to display in the interface. Does anyone know if there is a way of doing this?
I want to do this to give the user the option of going directly to my custom dials rather than having to tediously search around in the Property trees.
I'm having a hard time following your question. In the Parameters pane, the name of the feature you're looking to play with is Property > Gear icon > Parameter settings > Path.
From the Property pane menu, toggling Edit mode to 'Yes' will allow you to multi-select the properties you'd like to edit and change the path all at once with context menu > Set > Property group.
If you mean to set the Property group from from code, I can dig up an example. If you mean you'd like to select a property group from within a Script, I don't know off the top of my head.
Yes, I meant using Script. All I really want to do is to get the properties of a particular group (for example, Actor/People/Real World) to display in the interface, just as if I had clicked on the group. This code
will switch to the Parameters tab, but I can't see how I can get a particular group to then show. I have been looking at DzProperty, DzPropertyGroup and DzPropertyGroupTree, but nothing I try seems to work.
This is not a major thing, but I thought it would add a little user functionality to my next project. I have already reconciled myself to just putting a message box up saying where my custom group is to be found.
