How do you fit a texture?
DreammysticDreammystic Posts: 6
I created a image that is in shape of a circle, I want to place it on top of a flat cylinder primitive I created in Daz3d. However when I do this, the texture is overly large and not centered. What I want to do is shrink the image size and put it in the center so the circle image fits perfectly with the cylinder primitive.
I have no idea how to achieve this, I tried using the layered image editor to do this but its rather hard, since I can't view my changes in real time. So I figured that there has to be a easier way to do this.
I would appreciate help! Thanks!
  • Canary3dCanary3d Posts: 2,020
    Do you have GIMP or an image editor? In DS, select the primitive and change your view to "UV view." That will show you the model projected flat on a surface - the texture template, like a texture map. I don't think you can save this view to a file but you can screen capture it - in windows 7, use the "snipping tool" and carefully select the area inside the black border. Paste that into a new image in GIMP and paint your texture over it, save the result as a JPG, and then load it as the diffuse color.
    (There are more accurate ways to get a UV template but that's the quickest and doesn't require another app)
    If the flat UV looks weird or totally squashed, your primitive doesn't have a good UV layout by default and needs to be remapped, which is a little more advanced.
  • DreammysticDreammystic Posts: 6
    Thanks, I'll try this and get back with you. Really I do appreciate the help!
    If it doesn't work or is too hard, grab a screen cap of your cylinder and I'll map a similar one for you. :)
    Your advice works perfectly, thanks a bunch!
