Tween Morphs for Genesis
murgatroyd314murgatroyd314 Posts: 1,544
edited December 1969 in Freebies
Daz still hasn't released preteen shapes for Genesis, so I took a stab at filling the gap myself.
http://www.sharecg.com/v/65619/view/21/DAZ-Studio/Tween-Morphs-for-Genesis
Requires DS4.5 and Evolution morphs (also includes custom morph elements).
648 x 899 - 239K
  • FabeFabe Posts: 225
    Nice,were do I install it?
  • KeryaKerya Posts: 10,943
    They are looking really good! Thank you!
  • edited December 1969
    i've installed in My Library but i can't find the morph .Any hint?
    Look under Parameters for..
    Actor/Female/Real World/Tween Girl
    Actor/Male/Real World/Tween Boy
    Actor/Head/Female/Real World/Tween Girl Head
    Actor/Head/Male/Real World/Tween Boy Head
    Actor/Upper Body/Torso/Female/Real World/Tween Girl Flat
    Actor/Upper Body/Torso/Female/Real World/Tween Girl Rounded
    edited November 2012
    Maybe this helps:
    http://www.daz3d.com/forums/discussion/518/P345/#161419
    Edit: mjc1016 was two seconds faster - and better. :)
    Post edited by Kerya on
    nope i'can't find anything in that path.
    I tried to rescan unsuccessfully.Any ideas?
    What version of DS are you running?
  • DanaTADanaTA Posts: 13,262
    These look great! Thanks!
    Dana
    i'm running 4.5
  • murgatroyd314murgatroyd314 Posts: 1,544
    Under DS 4.5, the main morphs do not show up under the Shaping tab, but if the product is installed properly, they will be available from the Parameters tab. If they aren't, check to make sure that the following folder exists:
    My Library/data/DAZ 3D/Genesis/Base/Morphs/Murgatroyd/Tween
    If it doesn't, you've got an installation problem. Find where the folder ended up (searching for tween should work) and move it to the right place.
    In the parameters tab the morphs are not showed and i've checked the path and inside i've found your FBMTweenBoy.dsf file .The path is correct !!!
