Snowy ground/terrain for daz?
Serene Night
I'm looking for a good snowy ground to use in daz. High res texture, and perhaps terrain. Has anyone seen one? I've found a couple but they tend to look low res or dated.
You could export a Bryce terrian (given Bryce is still free) and use this product Let It Snow DS Shader
This is how I made this image. I used the above shader on the small trees/shrubs, on the fence, rock and terrain.
With this one you can use any terrain you want...
http://www.daz3d.com/shop/software/shaders-materials/let-it-snow-ds-shader
Then there is this set...
http://www.daz3d.com/shop/winter-kingdom-castle-ruins
This one looks good, but it requires the Worldbase XT, which is 29.95: http://www.daz3d.com/shop/snowlands-pak-for-worldbase-xt. That might be more than you want to spend if you're just looking for snow-covered ground.
I highly recommend the Let it snow Shader. It can be used on any set at any time.
Theres this one by Flink at rendo
http://www.renderosity.com/mod/bcs/flinks-snow-ground/90417
