Issue with AssaSIN render
dawgzangdawgzang Posts: 16
Hi
I downloaded/installed the new AssaSINs pack and put some items on Genesis. When I render I get strange items over eash breast and shins. Is there a way to turn these off in the render? I have attached a render for help understanding issue.
Thanks
450 x 600 - 154K
  • 3DAGE3DAGE Posts: 3,311
    I don't have that item, but,...
    those look like helper objects,.. to allow you to adjust some part of the clothing.
    There should be a shader for those in the Surfaces tab,. and you can set that to Invisible / transparent,. or, there may be a Materials Pose to do that for you in the materials pre-sets.
    Hope it helps :)
  • dawgzangdawgzang Posts: 16
    Thanks 3DAGE, you were very helpful.
    For anyone having the same issue here is where I found the controls...
    I found one set under the Actors, Wardrobe & Props tab / Editor / Top / Helpers / Opacity Strength set to 0
    The other set was under Actors, Wardrobe & Props tab / Editor / Skirt / Helpers / Opacity Strength set to 0
