Carrara crease question
Sonofbelmont
Hi
I've noticed that adding a crease to an edge will make it show up as a line in Vectorstyle 2 and I was wondering if there is a way to import the creases from one model onto another model of the same topology similarly to the way to you can create morphs?
any help would be appreciated
thanks
Post edited by Sonofbelmont on
HI Son of Belmont :)
Morph targets use the positions of the vertices (x.y.z.) to change the position of those vertices on the main mesh, but they don't change soft or creased edges,. so,. simply,. no, you can't load or transfer, the creased or smoothed edges from one model to another,.
with the exception of duplicating the original model.
