Animate Opacity of an object
mobilefinitymobilefinity Posts: 0
I've been trying to figure out a way to animate opacity from 100% to 0% across a series of frames. Is this even possible with Daz? I have pwEffect, but haven't been able to figure it out there either.
Thanks!
    How about giving this script a try
    https://sites.google.com/site/mcasualsdazscripts/texanimfords3
    You would need to make a couple of maps for to use for the transparency maps...the nice thing is, you could probably use 512 x 512 squares...at least one full white and one full black. And the item won't be able to have it's own transparency maps...
  • ReDaveReDave Posts: 815
    You can do that in Shader Mixer. My machine is rendering so I can't check and the names could be wrong, but simply find the Utility->Variable[Fixed] brick and either drag it or double click it. The drop-down on it should read "Ci", select "time" instead. Connect it to the opacity entry on the DAZ Default Material brick. If you need the fading to go in reverse, add a Mathematical->Binary brick, and insert it between the Variable[Fixed] and the DAZ brick. Connect the Variable to the second connector of the Binary brick. Type a "1" on the first input and select "Subtract". "time" goes from 0 to 1 irrespective of how long your animation is, so if you need the fading to start on a specific frame it may be better to just duplicate the scene and devote the copy just to the fading animation.
