One Click Wonders for Vue
![Martinjfrost](https://delorean.daz3d.com/forums/uploads/userpics/600/n7081FE794147.jpg)
Ever wanted to put a photo real distant hill side texture on your terrains in vue, with no mess and no fiddling?
One CLick Wonders - Flowering Hills will do the job. Spring and summer procedural vue materials designed for mid to distant terrains will instantly bring your vue render alive.
Flowering Hills Landscape Materials allows you to use simple or more complicated mixed and layered procedural materials with ease. Or if you want you can mix them, layer them or adapt them to your hearts content both with other One click wonder materials such as the sedimentary rocks or with other materials in your library. They are intended to build on and compliment the existing One Click Wonders Rock and landscape Materials in volumes one and two of this series by adding a new dimension to their rich color and texture palettes with subtle and complex shades of heather, gourse or other distant fields or hillsides with mixtures of grass, rock and wildflower colors and textures. They have been designed to mirror those hues and looks found in nature using the creators extensive travels and observations of the natural world to build upon to create a simple to use yet sophisticate set of Vue materials.
This range of One Click Wonders products was orgionaly hosted at Cornucopa3D and RDNA but when daz and Runtime DNA merged I thought it would be a nice range of products to offer exclusivly at Daz 3D This is the first in the series , the others will hopefully appear in my store over the coming months
And dont forget to pick up some bargains in my store during the premier artists event catch up sale! HERE
If you have ever wanted to quickly turn the terrain (of any size or resolution) you have just created or imported in to your scene, or even a fast rendering detailed material for your for-ground terrain, then one click wonders will make that happen for you! Harnessing the incredible power of displacement for close up renders and low polygon models to give it that extra detail, or the self same materials with normal bump mapping for faster rendering on objects that do not need displacement its all here for you!
This Product includes: Seven procedural materials for Vue 9 and up for application to terrains or objects in your Vue scenes.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/93/21f5e1eaa65a48777a6af18235caed.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/af/d6e7d604f7fd281f14ea2e1f4f0417.jpg)
