Shaders not loading?
I'm not new to how to use shader and mats, but I'm more of a Poser guy.
So I am trying to load a shader on Zero My Hero, but the shaders won't load. I even reinstalled the product. So what could I be doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 102,601
    edited October 2016
    Make sure you have both the model (in the Scene pane) and the surface (in the Surfaces pane) selected. Using the Surface Selection tool, from the Tools menu, will do both (as long as the surface you want isn't buried under another, as with the inner eye surfaces).
  • Yep.
    The eye shader works just fine. It's everything else that's not loading.
  • Something odd that just happened. I was toying with the Shader Editor and messing with colors...nothing happened. Then I clicked on the Zero My Hero shader mat and it worked all of a sudden. Now to see if the rest works.
  • Oh! Ok. I get it now. Select in the editor each piece and THEN load the shader.
    Thank you Richard for the quick response.
    Slowly moving over to DAZ Studio, which means a new learning curve
  • why the hell do shader not load, just old ones and they dont work either even on cubes
  • why can't these people at DAZ help???????????????????????????????????????????????????????????????????
  • felisfelis Posts: 4,655
    Which shader are you trying to apply, and what is your workflow?
