DS 4.5 Instance Spacing
barbult
How can I control the spacing between my instances when I use "Create new node instances" in DA 4.5? I'm Using the latest Beta 4.5.1.41 on Windows 7 64 bit. I created 10 instances, and they are spaced very far apart.
i always edited them by hand...even if they let you control the spacing, I often need to change rotations and height and stuff. But yeah if there is a way to automatically have it change that stuff would be nice.
So far manual placing I am affraid.
Try using the Align pane - still a two step process, of course, but if you want regular spacing it may help. You could also look at Send in the Clones 2.
Thanks, the align pane was new to me. I played around with it some, and I think it will help.
Except it doesn't seem to work (instancing; that is using SITC). :down:
